I don't think you'll be able to remove the door handle with the door shut (one of the door handle retaining screws is in the side of the door). I think the only way would be to try to get the door card out (not sure if this is possible with the door shut? Could be difficult as there are also screws holding the door card that could be inaccessible with the door shut). Once that is off you should be able to access the lock and remove it without removing the door handle (it's held by a screw at the back).
- Mk2 Golf GTI 16v, 2-door, Tornado Rot, BBS RS, 1988 - SOLD
- E30 325i Coupe, Manual, Alpinweiss
- E30 325i Touring, Manual, Diamantschwarz x 2
- On the lookout for another E30 325i Coupe, Manual (red would be nice)...
