Results 1 to 10 of 12
Thread: Door handle problem
    Door handle problem
    My daughter is so frustrated with the Mk2 rear doors, I press the door handle all the way and still don't get that 'click' to open, now it's getting worst and worst I need to open the door from inside for her to get in.
    I replaced one with new door handle but problem is the same, is there any thing can be adjusted ?
    Feb 2010
    Canberra
    There should be an adjustable part on the inside of the door handle (Gold part in picture) when its off that you can adjust:
    85' MKII GOLF GTI - GTI 85T - First cruise was 4000km in 2.5 days. It's Evolving!
    06' MkV JETTA TDI - Stock To Shock
    Mar 2009
    Melbourne, Victoria
    Check the latch rather than the door handle. I have found that this is usually a bigger problem rather than the handle.
    1991 MK2 GTI
    Dec 2008
    Bentleigh, Melbourne
    Also check that the stiker pin hasn't moved.
    mine had moved and door wouldn't shut/open properly
    Oct 2009
    Williamstown, SA & Broome WA
    Good question and useful answers! My red soot box is off the road with a list of things to do to it, and this has just jogged my memory! My driver's door is bad and I gotta do that to!
    May 2010
    NQ
    Some good tips here.
    Find it strange that its the rear handles your having trouble with, you would think they would get the least use?
    My front handles, particularly the drivers door are shaged!
    MK2 - *Insert list of dealer purchased extra's/standard features here*
    80 series - The MK2's BIG, Sooty, polar opposite...
    HAHAHA
    Quote Originally Posted by ryana89 View Post
    Cos I'm a old family man ... LOL
    Thanks for the tips, I'll check them on the w/e
    Jan 2007
    Same on my car, both the rear doors are harder to open / close than fronts and they make a "clink" sound. No big deal as they hardly ever get used.
    07 GTI
    APR stage II
    Dec 2007
    Perth, WA. *YAWN*...
    Take the handles off again and have a look at the metal lever inside the door that the handle tab actuates. It may have snapped, or worn down so that the y-shaped rotating lever in the handle cant make contact with it.
    I find the rears fail due to a LACK of use. They seize up and corrode, go brittle and shatter.
    just another possibility...
    Back to this problem.
    Eventually I bought this Genuine Hella door handle pair eBay Australia: Buy new & used fashion, electronics & home d.
    Woooo it works perfect, both rear doors open easily. Lesson learned, never buy cheap Chinese Mk2 door handle from ebay
