load that dvd lazy bones
You need to set the screen resolution to 1280-1024 before it will think about loading.
You could hook a 17inch monitor onto the laptop to get it to load. When you run it though you'll lose a bit off the side of the screen. To shut it down if you do that you need to use ctrl alt delete.
Its a dvd as well on a cd.
This car starting issue was resolved, but had an interesting conclusion.
It was still running heaps rich and then eventually wouldn`t start.
The fuel pressure reg was sucking fuel through the diaphram and into the inlet manifold. That`ll make it run rich![]()
It was heaps easier to tune with a new FPR. Still Hunts for a minute on cold start, but drriveable and idles sweet when warm.
