Results 21 to 30 of 35
Thread: Dodgy Starting Mk2
  1. #21
    If you have 3 wires but one of them has a shield around it, then treat it as being 4 wires Matt. The shield must be earthed to give the ECU something to reference the signal to.
    The whites can be connected either way.
  2. #22
    Oct 2005
    Dandenong North, Vic
    Yes, the shielded wire was not part of the 3 pin connector comming from the loom. It had a loop crimp which earthed somewhere, I think on the head cover.
  3. #23
    Camden, Sydney
    Well I have it wired exactly like that and the car still starts badly and hunts up and down. Runs OK, when warm, but still smells a bit fuelly.
    I reckon either I have another duff sensor, or its something else.
    Any ideas chaps?
  4. #24
    Oct 2005
    All I can say is when I hold the WOT (full throttle) switch on the G60, the idle hunts up and down. Maybe you have a stuffed idle or full throttle switch ? Gavs the expert
  5. #25
    Oct 2005
    Nowra, NSW
    my car hunts up and down when i first start it for a bit, after that its fine.
  6. #26
    syncro Guest
    Check the adjustment of the full throttle/idle microswitch. This causes these sort of problems.
  7. #27
    Camden, Sydney
    Yeah thanks guys.
    I drove it today and it hunts up and down when you first start it, hot or cold and then is fine when its running.
    Feels a bit underpowered, but that could be the Aussie Mk2 syndrome.
    When you go to start it, it cranks over weakly for upto 20 seconds sometimes without starting, almost like it is starving of fuel.
    I`m gonna check the microswitch next, any other suggestions guys??
  8. #28
    Crappy starter motor or bad connections/earth. A bad earth between the engine and battery won't help matters in the running department either.
  9. #29
    Oct 2005
    Did you sort out the Vac lines ? Heres a pic of my old motor and an ETKA dump with the Vac lines (T piece posi 9). I had a look in my Bentley manual, kind of points to fuel pressure checking or air flow sensor. Can you still smell fuel ?
  10. #30
    Camden, Sydney
    Thanks Voy thats a very helpful pic.
    The vac lines are not routed that way, I`ll sort em out and report back.
