Page 1 of 4 123 ... LastLast
Results 1 to 10 of 35
Thread: Dodgy Starting Mk2
    Camden, Sydney
    Dodgy Starting Mk2
    Mk2 Digifant Aussie Car
    Goes OK, but usually when hot it starts by coughing and spluttering and then runs ok.
    Smells of fuel and doesnt run as well as it should. uses heaps of petrol too.
    Cold start is not too bad.
    Changed the fuel pump relay. Can someone with a digi Mk2 look at the vacuum lines from the throttlebody and tell me where they should go, this one has two hoses, one from each outlet, joined by a T and going to the FPR. Is this right?
    Bad water temp sensor MAtt.
    Unless it runs better when stone cold then it might be the lambda probe
    Jun 2006
    Hornsby
    if u show me a pic mate i can check mine
    Camden, Sydney
    How many water temp sensor matter Gav?
    I changed the blu two pin one on the top of the water outlet, there is another underneath, which I thought was for the gauge only.
    It does actually run better stone cold.
    I was thinking Lambda probe, will hook it up to the VAG com and check tomorrow.
    Apr 2006
    Asaka-shi Saitama Japan (from Tassie)
    cold start injector running more than it should? do digi run a thermo time switch on the 5th inj?
    Cheers, Benny
    www.axesent.com.au
    Yeah the blue one for the ECU.
    The good cold running points to the probe or wiring mate.
    Not sure that the VAG-COm can do much for you. You can check the output of the probe with a voltmeter. Monitor the purple wire with respect to earth and you should see the voltage rise from 0 to 1 volt as the engine warms up. Once up to temp the meter will not be able to keep track of the voltage because it will constantly be changing. As it and the ECU alter the mixture. If you floor the throttle it'll go to a full rich state and then when you back off it'll drop to zero until the idle cuts in. This is because of the over-run cut off.
    If it doesn't work as described above you need to check that the heater wires are ok as well as the earth and signal to the ECU.
    I reckon it runs lumpy once warm because it has nothing to gauge the fuelling on so runs rich to avoid engine damage.
    Jun 2006
    Hornsby
    isv? not sure tho
    Camden, Sydney
    That sounds exactly like it Gavin, I can read the lambda output with my 1551 machine, but the symptons you describe are right on the money.
    I`ll try it tomorrow and let you know how I go.
    Or not as the case may be ;0)
    Camden, Sydney
    Yeah the car starts great dead cold and worse as it gets hot.
    However, I cant get the lambda out of the manifold.
    We tried for ages today, but its up behind the engine near the firewall.
    Its welded itself in there with the heat. I even tried a big spanner on the sensor and an engine crane connected to the spanner and it still didnt undo, just lifted the car!!
    I`ve already cut the wires as the spanner wouldn`t go over the connector, so I have to change it now. Aaaargh
    I`m thinking maybe just put another sensor in a more acessible part of the exhaust.
    As for sensors, I have lots of Mk3 ones which have an extra grey wire. Can I use one of these if I omit this wire? There are 2 white wires, how do I know which connects to which?
