Results 1 to 5 of 5
Thread: Dodgey right rear parker
    Jul 2005
    Melbourne, Williamstown
    My right rear parker hasn't worked for a good 6 months now, it's a miracle I haven't been pulled over for it.
    It's not the globe as I can swap the globe from the left hand side and the problem stays.
    I've checked the connections and they seem to be good at the base of the bulb tray.
    Any ideas guys? Could it be something as simple as a fuse? which I haven't checked by the way.
    mk2 GTi 16v
    Corrado G60
    Oct 2006
    Suspecting a localised problem, just wondering, is the thing earthing properly? One would think that none of the park lights would work if the fuse was blown. Does it run an earth wire to another part of the body or does the park light assembly earth via mounting screws?
    Jul 2005
    yeah but you never know those crazy germans
    mk2 GTi 16v
    Corrado G60
    brackie Guest
    Trace back
    Assuming the earth is OK (test with a mulitmeter) go to Supercheap or similar and buy yourself a test light with a needle probe (just a few $$s). Earth it with the clip and then trace the coloured wire from the +ve globe contact back toward the fusebox by probing the insulation with the needle. You'll find it
    Jul 2005
    Thanks will give it a go.
    mk2 GTi 16v
    Corrado G60
Similar Threads
  1. Funny noises from the rear ??
    By Subie25L in forum Mk5 Golf & Jetta
    Last Post: 10-05-2007, 11:22 PM
  2. OEM 25th Anniv Front & Rear valance
    By jbot in forum Mk4 Golf & Bora and New Beetle
    Last Post: 21-02-2007, 08:59 AM
  3. Removing rear window mk2 gti
    By ausgolfer in forum Bodywork/Trim & Detailing
    Last Post: 19-01-2007, 10:13 AM
