Results 1 to 10 of 12
Thread: Disassembly of the Cluster
    May 2010
    NQ
    Hello,
    Planned on replacing/testing the oil pressure and water temp warning LED's in the Golf today. Had no problems taking the dash apart and removing the cluster.
    However I've spent the last hour trying to figure out how to "unclip" this connector so that the flexy printed circuit will allow me access into the internals of the cluster, with not luck
    All the nuts/screws are undone, the only thing stopping me from opening it all up is that connection (big white plug with greenish looking plug inside it). Does anyone know what to do/how to disconnect it?
    PITA of a job.
    EDIT: Figured out how to do, have to slide it whilst using a flat head screw driver to lever it up.
    Got into the insides of the cluster and decided its to dangerous to play with such old, brittle equipment, the LED's can stay dead.
    MK2 - *Insert list of dealer purchased extra's/standard features here*
    80 series - The MK2's BIG, Sooty, polar opposite...
    HAHAHA
    Apr 2008
    You're keen!
    The MFA stopped working in my cluster and I got it fixed for $70. There is an old school tech dude in Sydney that I was told about.
    That's an option...
    Feb 2009
    NSW
    lol! mine keep pulling out of the clips when I take the ribbon off! I need to work out why my MFD doesn't display MPG I get 99.9!!! Aweseome fuel range if only!
    May 2010
    NQ
    Put it all back together and went to put it in the dash.
    Speedo cable has also fallen apart at the connection to the cluster.
    It all connected up though and works, just with alot of tappety/knocking sounds.
    Probably time for a new speedo cable?
    Don't spose that tech can also replace dead LED's?
    HAHAHA
    Sep 2009
    Heidelberg, Vic
    Ryan, I got an entire new cluster for $35; all I wanted was the Perspex cover
    You could source a temp replacement to get you mobile and then look at getting yours repaired (to maintain your mileage) We have a few places in Melbourne also that repair clusters but they aren't always cheap.
    Dave
    1990 MK2 GTI
    2009 MY10 Tiguan 147
    2010 MK6 GTI
    May 2010
    NQ
    Thanks Dave, I may just take you up on that offer.
    The car is in a runnable condition, the only suspect part at the moment is the speedo cable, plus it seems virtually impossible to properly connect the speedo cable up.
    I'm just on the verge of replacing the front tyre's + a bit of steering work.
    The current cluster doesn't have working water/oil warning lights aswell as a MFA that doesn't appear to work at all.
    I'll send you a PM.
    HAHAHA
    Jul 2005
    Newcastle, NSW
    Quote Originally Posted by ozgti View Post
    You need to make sure the vacuum line is in good condition and connected to a vacuum spike on the intake.
    Feb 2009
    NSW
    The swingometer works, but the digital readout doesn't.
