I would set it with the chip fitted, then test drive to make sure there's no pinking.
I have always checked them at tickover.
From what I understand the digifast2 chip changes some of the timing settings.
Should I still set the timing to 6 degrees before to dead centre @ 2300ish rpm ? Or should I put the original chips in to reset the timing then reinstall the digifast 2 chips.
Ps this has come about due to new cam seal being installed
1990 MK2 Golf GTI
Hi Gavin
when you say fitted chips, do you mean the origional chips or the digifast currently fitted ?
1990 MK2 Golf GTI
Doesn't matter what chip is in there for me. The reference is TDC, I'd set it at tickover and then drive it. No pinking , then advance it a bit more. Repeat until you get the most advance without pinking and it still ticks over nicely.
Alex I'll ring u tmw
Alba European
