Results 1 to 5 of 5
Thread: Digifast 2 setting timing?
    Sep 2011
    From what I understand the digifast2 chip changes some of the timing settings.
    Should I still set the timing to 6 degrees before to dead centre @ 2300ish rpm ? Or should I put the original chips in to reset the timing then reinstall the digifast 2 chips.
    Ps this has come about due to new cam seal being installed
    1990 MK2 Golf GTI
    I would set it with the chip fitted, then test drive to make sure there's no pinking.
    I have always checked them at tickover.
    Sep 2011
    Hi Gavin
    when you say fitted chips, do you mean the origional chips or the digifast currently fitted ?
    1990 MK2 Golf GTI
    Doesn't matter what chip is in there for me. The reference is TDC, I'd set it at tickover and then drive it. No pinking , then advance it a bit more. Repeat until you get the most advance without pinking and it still ticks over nicely.
    Aug 2007
    Alex I'll ring u tmw
    Alba European
