Unfortunatly I got engrossed in working on it to much from here and compled the A/C switch and Demister switches without taking photos.
But heres the end result
As the A/C and demister have 2 lights (on to tell you when the swith is on and one to light it up when you turn the lights on).
The ones to tell you that the switch has been activated work (better) now.
And Im not sure how I managed to do this, but when I soldered the LED into the Light switch, I somehow attached it to the terminals that are always live when the ignition is on, but LED's can apparantly last for over 10 years (constant use) so Im not to worried.
Next will have to be the Cluster (tacho/speedo)...... if Im gain
