Do you think the sound is coming from the right inner or outer?
The drive shafts are meant to be different thicknesses
I have been experiencing grinding (from the left side of the car) during hard accelerations from 1st to 2nd gear and also clicking noise when at full lock (to right only). I had a quick look under the car and noticed some grease spraying marks although none of the rubber boots looks torn. And i also noticed something abnormal, the right side drive (longer) shaft appear to be thicker (in diameter) when compared to the left side. Is this normal?
Would like to know this before deciding to only replace CV Joints alone or complete with drive shafts (if its got the wrong shaft). Any recommendation for a local supplier for CV Joints / Driveshafts?
Got Turbo Inside
MK2 - *Insert list of dealer purchased extra's/standard features here*
80 series - The MK2's BIG, Sooty, polar opposite...
HAHAHA
check the wheel bearings and strut top mounts too just to be safe.
mk2 GTi 16v
Corrado G60
Its coming from the left.. can't tell its inner or outer.
Thanks.. at least I can save some $$ by ordering only the CV Joints knowing i have normal driveshafts now
---------- Post added at 09:11 PM ---------- Previous post was at 09:09 PM ----------
Thanks. I will find sometime to check this 2 items.
How do i check the strut top mounts? Is it by jacking up the car and lift up the wheel to see if the struts pops up?
Got Turbo Inside
To check the strut top mounts. Lift the bonnet. Jack it up. And as the front wheel lifts off the ground watch the top of the strut from the engine bay. If it drops considerably it's well worn. A few mm would be ok. Also try lifting the wheel when it's off the ground for a similar effect.
