![Support VWWC](https://www.vwwatercooled.com.au/forums/images/banners/supporters.gif)
Jayjay..
Thanks mate.. its most definately a digifant!!
Hi Rossco,
I have just purchased and fitted one of these for less than $300 AUD.
85-98 VW Golf GTI Jetta 1.8L 2.0L MK Exhaust Header OBX: eBay Motors (item 160431433159 end time Jun-04-10 09:21:13 PDT)
It fits like a glove - just have to get a connection tomorrow from Header pipe to Cat (as the connection is about 7mm larger) !
Cant wait to drive it. Ill drop you some feedback on the differance it makes.![Banana](https://www.vwwatercooled.com.au/forums/images/smilies/emo_banana.gif)
Rob
Thanks Rob, look forward to what you think
Rossco,
Job completed - makes a huge differance - much closer to a uk spec GTI now.
Loads more mid range power - car revs out consistently now - the whole car is much smoother too. Well worth the $330 it cost all up (fitted it myself)
The header pipe i was sent had a 50mm connection - my car had a 45mm joint to the cat...there is also a 55mm i beleive.
something to be wary of to make life easier !
where did you get the headers from america or the uk?
- You may not post replies
- You may not edit your posts
Forum Rules
