you can import an manifold from europe ;P
or fit a mk3 and get it made to fit the standard system.
2.0 is a simple swap, the only hard bit is that the block is taller so you need a longer downpipe on the exhaust and the throttle body will hit the bonnet when shut! but you can fix this with a hammerI will upload a photo of what i mean later tonight.
2.0 gives the car more torque and nicer to drive![]()
