Results 1 to 4 of 4
Thread: Coolant temp sensor connector terminal
    Apr 2010
    City of Swan, WA
    Hi all,
    My coolant temp sensor (blue) connector wires is breaking too close to the connector (can't splce, have to cut it off). i was wondering if this terminals i found on ebay are same as the ones in the connector?
    BOSCH INJECTOR PLUG TERMINAL X 8 - Suits EFI Plugs | eBay
    Apr 2011
    Bannockburn
    your local VW dealer should have (in Stock, wiring repair, yellow cables) ready prepared pins with a piece of wire on it and also 2 conectors.
    those pins that you found are to big, if it are these in the pic. the discription says for injectors, they will fit.
    you can use also the pins from the DIN Radio plug, they ar the same size.
    Apr 2010
    City of Swan, WA
    Thanks! I will give some of them a ring.
    Apr 2011
    Bannockburn
    here is the part no. 000 979 133A
    these are with the gold contacts.
    dont no the no. from the normal ones
