George, you've got a rare cluster there! (with the fuel/temp being vertical)
That arrow indicates/flashes when to change 'up' gear (if it's all wired up right)
Hey guys, i have a mk2 dash in my mk1. I've always been curious what this guage does, or indicate. I've never known and have always wondered what it was for. I thought it could have been for fog or something, but wasnt sure. Anyone able to give me a description on it? Cheers
- Brown U.S import 81 cabby
- 88 Honda crx b18cr
MK2 - *Insert list of dealer purchased extra's/standard features here*
80 series - The MK2's BIG, Sooty, polar opposite...
HAHAHA
Wow !! Thats awesome, thanks man. I just did a google images search and i see what you mean about the vertical fuel and temp. I wonder where i can find a diagram to wire up the up gear. Im assuming i need to wire it to my tacho/rev somehow
But once again thanks Ryan !!![]()
Wiring up can be the fun part.
Electrical Systems
Kinda hard to explain but that link should do it.
Depending on the era, MK2 clusters use inputs from various sensor/switch's as-well/or the ECU (ie MPG, AVG etc)
If you don't have it already, you will require the proper 28pin plug/s set-up that connects to the cluster.
Please correct me if I have said anything wrong/misleading*
HAHAHA
Ive got a very similar cluster in my early mk2 and that gauge is the mpg indicator. Operates by vacuum I think.
Also mine is in mph
