Results 1 to 10 of 15
Thread: Check this out corrosion after 4 days
    Sep 2011
    Hi all
    I rebuild my 020 gearbox last week but looks like I used the wrong input seal so had to pull it out again, anyway I pulled the 5th gear cover off and this is what I found.Check this out corrosion after 4 days-image-jpg
    Corrosion of the gear. Alarmed at this I dug deeper and found Check this out corrosion after 4 days-image-jpg
    More corrosion, all the gears have been affected and to a lesser degree other parts.
    If put nulon sae 80 api GL4 in the gearbox on Tuesday, and the above is what I found today. How can this be?
    I believe the is the right oil to use, am I wrong?
    Any thoughts? Best recommended remedy to clean it all ?
    1990 MK2 Golf GTI
    May 2010
    NQ
    Try wiping/scrubbing it off with some kero (may have to let it soak).
    Do you think condensation could have build up? That's weird.
    MK2 - *Insert list of dealer purchased extra's/standard features here*
    80 series - The MK2's BIG, Sooty, polar opposite...
    HAHAHA
    Perth. WA
    Looks to have been assembled dry, also note overuse of silicon sealant on jointing faces.
    As the silicon cures some types express acetic acid ( from memory ) which can basically acid etch bare steel, likely making it more succeptible to moisture attack.
    If the seal was leaking oil out it will certainly allow the passage of crap in. Had you washed it with water / degreaser to remove the oil leakage before disassembly ??
    Go buy a tube of VW jointing paste for the trans reassembly .
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
    Sep 2011
    Do you think the oil may be the issue? Should I chuck it use different oil?
    Any recommendations on oil? I can't find the redline product which people recommend. I've used cast roll vmx80 in the past, I wanted to try something diffrent thence the nulon. The api gl 4 oil isn't that easy to find
    1990 MK2 Golf GTI
    Jun 2011
    Sydney NSW
    Quote Originally Posted by roccodingo View Post
    Yes, there are two types of silicone sealant. Acid Cure (acetic acid), and Neutral Cure (ammonia). You need to be careful with acid cure as it can damage components. I used to use silicone sealant on my radiator hoses on my old Torana after a mechanic recommended it. The problem was that if some of the raw sealant got into the radiator, the acetic acid would end up corroding the radiator tank soldered joints.
    Whatever sealant you use, more is not necessarily better. Bits can break off and end up in galleries or pumps or bearings.
    On assembling the gearbox (or any engine transmission unit), you should always use assembly lube. It is heavier and more clingy than regular engine/transmission fluid, and protects surfaces for that critical first start, and until the normal lubricant has a chance to coat all surfaces properly.
    Sep 2011
    Thanks for the info I'll take note on thr. Do you think the oil will now be contaminated or should it still be good to use?
    1990 MK2 Golf GTI
    Adelaide hills, SA
    The oil is the least of your worry. I'd be concerned about the condition of the bearings and the gears. Change the oil and put some extra additive in as well. I suggest the Nulon G70 or Moly 2.5
    Aug 2007
    Oh dear never ever seen that. Way too much sealant there mate, only needs 2mm bead, id use wurth sealant and not that horrible stuff there. Also id recommened Fuchs synthetic oil in that box, just saying
    Jmac
    Alba European
    Sep 2011
    So looks like the consensus is I used a stupid amount of sealant, left it dry for a few days before adding the oil, allowing the sealant curing process to start eating way at the metal in the gear box?
    Thanks all for the advise, I bow my head in shame, consider me scolded and hopefully educated.
    Cross fingers the mighty 020 can recover from this abuse or it's off the the wreaking yard to try and find another gearbox. mk2 is out of the question in Brisbane so a mk3 gearbox will have to do.
    Jun 2011
    Sydney NSW
    Not necessarily a new gearbox. If you have the time and are prepared to do the disassembly and reassembly, you could basically do an overhaul.
