Check this out corrosion after 4 days
Hi all
I rebuild my 020 gearbox last week but looks like I used the wrong input seal so had to pull it out again, anyway I pulled the 5th gear cover off and this is what I found.
Corrosion of the gear. Alarmed at this I dug deeper and found
More corrosion, all the gears have been affected and to a lesser degree other parts.
If put nulon sae 80 api GL4 in the gearbox on Tuesday, and the above is what I found today. How can this be?
I believe the is the right oil to use, am I wrong?
Any thoughts? Best recommended remedy to clean it all ?
1990 MK2 Golf GTI
- You may not post replies
- You may not edit your posts
Forum Rules
