CHB gearbox on ABF engine- clutchproblem
Hello
I just did a Mk2 conversion from a GTi 8v ( RV engine) to an ABF (16v) engine. I kept the old gearbox which is a CHB ( 5speed manual).
The torque output of the ABF engine is much higher than the RV engine, so I´m thinking to get a better quality clutch. I fitted the original clutch but it starts slipping at acceleration at higher rpm´s.
My question is, if somebody has done already a conversion like this and what sort of clutch and pressureplate you were installing with this package. I would be very happy if I could get some advice what I should use and where I could get it from maybe with a part# too here in australia. clutch has 24 splines/ 210mm
Many thanks
Stefan
- You may not post replies
- You may not edit your posts
Forum Rules
