![Support VWWC](https://www.vwwatercooled.com.au/forums/images/banners/supporters.gif)
CHB gearbox on ABF engine- clutchproblem
Hello
I just did a Mk2 conversion from a GTi 8v ( RV engine) to an ABF (16v) engine. I kept the old gearbox which is a CHB ( 5speed manual).
The torque output of the ABF engine is much higher than the RV engine, so I´m thinking to get a better quality clutch. I fitted the original clutch but it starts slipping at acceleration at higher rpm´s.
My question is, if somebody has done already a conversion like this and what sort of clutch and pressureplate you were installing with this package. I would be very happy if I could get some advice what I should use and where I could get it from maybe with a part# too here in australia. clutch has 24 splines/ 210mm
Many thanks
Stefan
Just order a heavy duty 020-spec clutch kit from the USA - VW Performance - Autotech Sport Tuning, Euro Sport Accessories, Inc - Performance and OE parts for Volkswagen and Audi, Techtonics Tuning, VW and Audi Performance Tuning and Repair Parts are all reliable suppliers.
Get a lightened flywheel at the same time and make sure you replace all the hardware, which is one-use only
1976 Project Carbon Mk1 - Sold! |
2015 Lotus Exige Cup |
F80 M3 Family Wheels
thanks mate ![Smile](https://www.vwwatercooled.com.au/forums/images/smilies/icon_smile.gif)
I found my issue, got the flywheel laithed but only the inner surface, forgott about the outer diameter as well...so the clutch had play-started to slip.
all sorted...
cheers stefan
- You may not post replies
- You may not edit your posts
Forum Rules
