Quote Originally Posted by ausgolfer
ah the pains of laziness. My MFA computer globe has been out for about a year now and I really should change it, but got my eye on something that might not require me to change it.
Don't I know it
What have you got your on
Anyway, if my memory serve's me correctly, you have to remove the radio head unit, the headlight switch(there's a screw behind it), under the handbrake indictor light panel, the closest switch panel to the insrument cluster. It's either a blanking panel or a switch(Mum's car is a blanking panel with the AC/Recirc switch next to it.) & there's a screw behind there. Two screws above the instrument cluster & I think there is one behind the heater control panel too.
Remove the facia & there two screw's holding the cluster in. Tilt the cluster forward & disconnect the speedo.
