Results 1 to 10 of 21
Thread: Carb questions
    Jun 2007
    Eastern Suburbs Melbourne
    should be a stamping on the side of the carb somewhere.
    VW used solexs, but also pierburg on mk2' 1.6's. you'd have to check yourself to be sure.
    i like volkswagens
    Gold Coast
    I think you're right pierburg rings a bell.
    Gosford Central Coast NSW
    one nice thing about hte stock setup is that you can easily rig it to get cold air from the front, whereas the aftermarket carb-top filters are so poorly positioned.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Gold Coast
    Excuse my ignorance, but, why is it an issue if a carb only sucks in hot air?
    I know cold air is denser than hot, but i thought that was only an issue for forced induction engines. If the air has been filtered why does it matter if it is hot or not? Also carb-top setup has a larger surface area too.
    Jun 2007
    it doesn't matter weather its on forced induction vehicle or not, the principle is the same, cooler air = better bang. (basically)
    it's just more noticable and more important for forced induction, because of al the extra air/pressure involved.
    i like volkswagens
    Gold Coast
    That makes sense.
    Does it have any negative affect on the engine, besides performance, in terms of cooling, reliability, etc?
    Jun 2007
    she might get a bit un happy sitting in traffic on a hot summers day, but that's bound to happen to some degree anyways.
    if the engine is standard, a cold air intake wont make much difference in this case, and likewise going backwards, wont make much difference, but it'd be slightly noticable when the car is in traffic (no air flow under the bonnet which means it's surrounded by warm air, where as cold air intake is lower to the ground and has better chance of breathing fresh air.)
    i like volkswagens
