Results 1 to 5 of 5
Thread: can kjet be fixed
    Apr 2010
    cape town south africa
    can kjet be fixed
    i have a 1.8 8valve jetta mk2 just wanna know if the kjet injectors can be overhauled or serviced becaus mine seems to dripping after the car has been driven and makes it hard to start after its been parked for a while some views bec ive had none from my fellow south africans on their forums
    Quote Originally Posted by wes csi View Post
    i alway thought that the biggist problem with k-jet injectors is the 'o' rings just need replacing.
    you say its hard to start, does the engine turn and not fire or does the starter struggle to turn the engine?
    Velly
    '91 2.0 8v GTI
    Quote Originally Posted by DubSteve View Post
    I have wood thinking about you
    Apr 2010
    well to make a long story short ive checked everything possible but when i pulled the injectors out they actually drip fuel when the car is not running so its actually flooded when its parked for a while new battery new alternater the cold start valve workes perfect i just want to know if they can be refurbed like diesel vehicles injectors at like a injection specialist thanx for replying
    There use to be a mob in Melbourne many years ago that did full K-Jet component rebuild's.
    But that's a different country to SA & also a very long time ago
    Dad took me there & had his Fuel Distributor Head & Warm up regulator reco'd
    This was my first ever dealing with K-Jet.
    For the price of getting your injectors stripped & service (if still possible) you'd be better off just buying a new set if you know what the problem is & your getting "brand new" items instead of reco'd ones.
    Or get another set out of a wrecked car thats a good runner.
    CIS injectors are approx $60US.
    PS. CIS injectors can also dribble if the mixture screw isn't adjusted correctly either. eg. CO% is way to rich.
    To test, you bridge out your fuel pump relay & run the pump at max & test the injectors & air flap plunger operation. Its better explained in a Bosch fuel injection book.
    But if the car mixtures are OK, forget the above mention.
    Perth. WA
    It is possible to reverse flush the injectors to clean the crud out of the filter screen in the injectors, but if there dripping I would say the pintle and seats are past there use by date. You can get new bosch injectors for around $50 AUD here South Africa, dunno...
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
