Results 1 to 10 of 13
Thread: Which Camshaft?
    Mar 2012
    Eastern Subs, Victoria
    Which Camshaft?
    Hi all on here,
    After a bit of advice on which camshaft to get for my Mk2 Aus spec Golf GTI, digifant 8v.
    Current setup is stock head with 2.25 exhaust and Ramair induction kit is on its way.
    Will be doing new lifters when I fit the cam, but will be keeping the original springs for now. Will be doing some head work later on and possibly a 2lt bottom end.
    Ideally I would like a little lumpier idle but would prefer not to sacrifice too much low to mid range.
    Have looked at the Autotech, Techtronics, Bahn Brenner and Newman ones. As these seem to be a good price for my fund situation.
    Any suggestions and thoughts?
    Apr 2008
    When I looked at a cam, the best solution seemed to be a 268 exhaust cam. The 272 was a bit lumpy for peoples tastes.
    The thing then is, your valves will now open down past TDC so you'll need to focus on maintaining the belts etc.
    Mar 2009
    Bamish...
    I went with the Autotech(AT) 270 cam and a few other goodies... seems to be a good balance. PM me for more info.
    Cheers mate
    Apr 2010
    City of Swan, WA
    I have got a Techtonic 272, bit lumpy but i like to 'grumble' at idle.. heeeheee.
    Got Turbo Inside
    Oakleigh VIC
    TT 268 is quite OK on the street. Should be OK with the digifant, worked fine on my KJet 2.0L
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
    May 2010
    NQ
    If you don't mind me asking, how did that affect the power band/where did it move it?
    2L 8V's seem pretty doughy standard, with power between 2500 - 4000.
    I know mine doesn't make power much after 4,000 though (on digi).
    MK2 - *Insert list of dealer purchased extra's/standard features here*
    80 series - The MK2's BIG, Sooty, polar opposite...
    HAHAHA
    Oakleigh VIC
    7? MK1 Caddy
    12 Amarok
    Aug 2006
    Richmond Vic.
    Schrick all the way....
    90 GTI Cab.
    83 Audi quattro
    Mar 2012
    Thanks guys, ended up going with Newman 272 due to it being ground for the original timing marks. So no need for a vernier. Ordered from TSR in the UK and they were very helpful.
    Next question, will new standard hydraulic lifters be good enough or should i be looking at heavy duty ones?
    Mar 2012
    Think She is in need of a new front plate.
