Results 1 to 10 of 10
Thread: Camira Bits that fit a GOLF!!!
    Camden, Sydney
    I was at Pic and Payless today and am able to answer a couple of the rumours about whether bits of Camira fit a Golf.
    My Mk2 Jetta has Camira front brakes, I established this, as I needed a brake hose. It looks like the calipers and vented discs simply bolt up to the hubs. I know it works for Mk2, will have a look at Mk1 tomorrow.
    The other bit was the wiring for the electronic ignition. The TCI module plug and all the wires to the dissy and the coil. Dunno if the module works, but I plugged the VW module in and I have spark. Easier than making a loom.
    And nice to see that the camira is good for something!
    Perth. WA
    I have a set of discs & calipers here from a camira if you want them, and the TCI module is common to a pile of cars, ( saw a list on a parts site somewhere...blew me away ) You can also get the hall sender as a seperate item now ( as opposed to VW selling you the whole distributor..)
    Pics available if requested..
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
    Camden, Sydney
    Yeah the guy at the scrappy says he sells loads of the wiring looms and TCI conectors to auto electricians.
    The hoses are different connectors on the brakes, but you can get em made up.
    imported_brackie Guest
    "J" car?
    Wasn't the Camira the GMH "J" car based on the Opel? That means it had it's genesis in Germany so maybe there's even more parts in common with the Golf.
    Gold-mk1 Guest
    chaps ? Whats a Camira...?!?!
    syncro Guest
    Quote Originally Posted by Gold-mk1
    1980s Opel/Vauxhall front wheel drive about the size of a Mondeo.
    Don't know what they were called anywhere else. Has been replaced by the Vectra.
    Gold-mk1 Guest
    Quote Originally Posted by syncro
    AHA !!! That'll be a vauxhall cavalier over here then, the taxi drivers favourite.....
    silva1 Guest
    camira
    i have camira callipers on my mk1 ' which made a good improvement, but the catch is that they have agreater fluid capacity which can lead to asofter pedal
    mk1has a76mm offset on the carrier & the mk2 has a90mm offset, what did you do loon??????????
    Jul 2005
    bradbury nsw
    the camira was general motors first world car ( the J car) holden in australia designed and built all the motors for em they have versions of this motor in daewoo ,GM took the company over because daewoo couldnt pay the bills
    1400 ,1500, 1600,1800 and 2000cc versions were built for other cars like
    astras ,corsas ,barinas ,nissan pulsars and vectras even twin cam versions
    all pretty yuk
    Mar 2006
    Roccodingo - am I understanding you correctly in that you are suggesting that the Camira carries the same Hall Unit? Fabulous tip - thanks!
Similar Threads
  1. Volkswagen Group Australia Sales Stats (Audi, SEAT, VW, VWCV) 1991-2008
    By phaeton in forum VW Watercooled Media Lounge & Interesting Articles
    Last Post: 08-11-2010, 10:52 AM
  2. Electrical problems with VW Golf V towbar
    By JandG in forum Mk5 Golf & Jetta
    Last Post: 08-03-2009, 08:50 PM
