Ok
Single piston calipers do apply even pressure to both pads, provided they are floating well.
Multiple pot calipers apply pressure over a wider area of the brake pad
Have the rotors machined and use some pads with more bite - like Ferodo DS2500 - that makes a noticeable improvement
Not many small cars have Brembo calipers
The Nissan 350Z has small two pot Bremobo's at the rear (running on a 332mm rotor) - but they tend to cost $600 from a wrecker
Most adapter plates are for calipers with radial mounting bolts (not OEM Brembo's with side mounting bolts)
You can get Seat Ibiza Cupra Brembos for 600 GBP and the adapters for 129 GBP - that's $1350 AUD but postage will be another $250 easy
You can also use front Porche 996/Boxter calipers, they cost about $800 AUD and the adapters cost $220 AUD
You need to obtain Seat Ibiza Cupra rotors, 305mm * 28mm to make this work
(there are probably after market rotor options available)
Pretty much any way you go BBK's are pricey so you need to be determined/committed
BBK's are awesome however
I have a HPA BBK on my Skoda Octavia and a Stoptech BBK for racing usage on my Nissan 350Z
Both are 6 pot with 14" inch two piece rotors - awesome stopping power (with a nasty price tag)
