Did you have 300hp+ power upgrade ? otherwise Mk2 brake is quite good, why do you want to change it.
I have A 1988 Golf MK2 and the brakes are working fine. I heard from a friend of mine that I can upgrade the brakes. I am thinking of upgrading it to a double piston ventilated disc brakes. Anyone who knows where can I get them from? I mean from which VW car? I heard from a Corrado? If so, wha model and year? Also would there be alot of modifications?
Thanks!
'88 Golf MK2 - Bilstein - BBS
Parts for sale http://www.vwwatercooled.com.au/foru...ff-102387.html
Sounds like you want Girling 60's. They allow you to run a 280mm disc and are twin caliper. however they're kinda weighty.
Some old audi's had them as factory. (100, 200's from the 80's)
You should be able to run a cupra or corrado disc. 280mm, narrow track, 4 stud, but you'll also need mk 3 2L style (narrow track) hubs. Our mk 2 gti's have a one piece carrier/hub (and 239mm disc). To run decent brake upgrades, you need the mk 3 2l stuff (256mm, an upgrade in itself). then you can run mk 3 style brake upgrades. 288mm require different carriers, the carriers that come standard on the Girling 60 brakes should fit straight onto mk 3 narrow track setup. (actually, they'll probably fit straight on a widetrack set up, using a widetrack , VR6 -280mm, disc.
hope this helps.
I'm saving the pennies to do what Jarred suggested, use the 256mm disc/hub set up off a MK3 GL (2.0).
I reckon this explains it nicely...
MK2 - *Insert list of dealer purchased extra's/standard features here*
80 series - The MK2's BIG, Sooty, polar opposite...
HAHAHA
I'm not to sure on shipping costs, probably not very nice considering how much the parts would weigh.
Was the MK3 GL Golf sold in the Philippine's?
Cause all you'd need to do is find one in a wrecking yard and take the front hub/brake set-up.
By the way, whats the current brake set-up on your MK2 (solid rotors up front, drums at the back???)
HAHAHA
Unfortunately they didnt sell golf's here in the philippines. All Golf's here are imports... my MK2 has stock brakes (solid rotors up front, drums at the back) Im actually thinking of buying big bumpers there and have it shipped here in the philippines... would you know if someones selling? I would want to compute how much would it cost me just in case.
Ahh, I see, you must have a standard (CL?) MK2.
I wouldn't be able to say who's selling bumpers atm, I don't know.
But have a look here for interests sake,
GermanAutoParts.com
Have a snoop around ebay UK or USA for those brake parts too.
HAHAHA
