Page 22 of 28 FirstFirst ... 122021222324 ... LastLast
Results 211 to 220 of 271
Thread: Bought a MK2 GTI
  1. #211
    Jan 2007
    Thanks for the kind words guys. Just got out of hospital and luckily all I've got is a fractured breastbone. Makes it painful to breath and I cringe even thinking about coughing but I can still fart like the best of them.
    Give me a few days and I'll check out how much damage there is under the bonnet. If the motor is OK I'll put it and all the fuel injection system into the MK1 together with all the electrics and dashboard.
    I've already lined up a cheap Mazda Eunos as my daily (1.8 V6). There's no way my wife would let me look at another old Golf and at least the Mazda has an airbag. Wish the MK2 did too as the impact on my breastbone is pretty painful. Makes me walk like an old man.
    Would be good if you could save the engine- would be perfect for your mk1 !
    Hope your getting better mate.
    07 GTI
    APR stage II
  2. #212
    I finally managed to have a good look at the damage.
    Bought a MK2 GTI-img_20151015_103236-jpg
    Bought a MK2 GTI-img_20151015_103250-jpg
    Bought a MK2 GTI-img_20151015_103256-jpg
    The chassis rails didn't take much impact so should be good and the suspension towers aren't damaged. It could probably get back on the road but it's going to take a lot of time and a lot of money. If I didn't have the MK1 I'd probably fix it.
    So instead I'll take all the good bits and make the MK1 that I've always wanted.
    What's left of the MK2 will be parked at Mums and who knows, maybe one day I might decide to get it back on the road.
  3. #213
    With that kind of damage, the shape of chassis can't be judged by eye I believe. Good thing about rural life style is you have unlimited space to store parts and shell
  4. #214
    You're right, until I strip it back I can't tell what the real damage is but at least it isn't as bad as I first thought.
    With 100 acres out at Mums I just need to remember where I put things so I don't loose them.
  5. #215
    Beware Policemen with axes.
    Bought a MK2 GTI-img_20151101_124245-jpg
    That will teach me next time to leave the keys with the car after an accident so it can be moved.
  6. #216
    Aug 2006
    Melbourne VIC
    What butchers
  7. #217
    Oct 2011
    Mackay QLD
    sgs parts plus have a mk2 golf wrecking , get hold of Geoff 02 9980 0000
  8. #218
    If I went back to a MK2 my wife would do nasty things to my privates.
  9. #219
    isn't that what youl want?
    9N3 Polo GTI - 91 MkII GTI - 16 B8 Passat 132tsi Comfortline
    Past - 14 MkVII GTI, 9n3 Polo GTI, Mk5 Golf GTI, Mk6 Golf 77tsi, Mk6 Golf 90tsi, Mk2 Golf GTI, Mk3 Golf VR6.
    Wanted: Mk1 GTI white or black
  10. #220
    Took off some of the bent bits to see if the engine would run before transplanting it into the MK1.
    Bought a MK2 GTI-img_20151224_094459-jpg
    Bought a MK2 GTI-img_20151224_094804-jpg
    Check out how much the brake reservoir pushes into intake pipe. Shows how much the chassis has twisted.
    Bought a MK2 GTI-img_20151224_094816-jpg
    The engine turned over and ran but there's something pushing onto the timing belt so it was only a short to make sure there's nothing wrong inside it.
    Next step - engine and gearbox out then I need to work out what to do with the shell.
