Page 10 of 28 FirstFirst ... 8910111220 ... LastLast
Results 91 to 100 of 271
Thread: Bought a MK2 GTI
  1. #91
    Jan 2007
    Paul sorry to hear about the oil cooler!
    Hope you got it sorted ok now.
    New wheels look great- really suit your color.
    What are they?
    They look like Audi rims?
    Not good news.
    Attachment 8841
    The oil leak goes for another 2 ks before the oil light and buzzer came on. Oil was pouring out of the oil filter. Turned out the oil cooler had a split O ring. These use water to cool the oil and are known to be unreliable so I took it off and fitted the filter direct to the oil filter housing. Just needed a shorter centre shaft from a MK1.
    You can see the longer centre piece on the right with the short one fitted. The oil cooler is below.
    Attachment 8842
    Now the good news.
    17s
    Attachment 8843
    Attachment 8844
    Looking good.
    Paul
    07 GTI
    APR stage II
  2. #92
    My oil cooler also is leaking but not severe, I was wondering how efficient and how necessary is the oil cooler is, my ex Australia released Mk2 doesn't have it, most SA and UK cars have.
  3. #93
    When I had the oil cooler working the max temp I'd ever see for the oil was 96, it usually sat around 90. Water temp guage never went above 1/3rd. Yesterday on the way to work I had to stop for roadworks a few times, the oil temp hit 100 and the water went 1/2 way before it started to go back down to normal. Today outside temp was 12 C and the oil and water were back to normal.
    I'm not worried by these numbers because it's pretty cold down here compared to Brisbane but I'd think twice before taking the oil cooler off if I lived in Qld and had to do stop/start traffic.
    Mine didn't have a slow leak, it worked fine right up until the O ring split sometime overnight with the cold. Saturday I drove to Sydney and back. Monday morning the oil started pouring out as soon as I pulled out of the driveway.
  4. #94
    Quote Originally Posted by golfmeup View Post
    What are they?
    Wheels are aftermarket multi fit. They have more holes than swiss cheese so I'll get all the extra ones tig welded before I put them on the car permanently.
  5. #95
    Jan 2007
    You would have to be running a 45 profile tyre by now wouldn't you Paul?
    In summer I've seen the oil temp go up to 110 or so in Brisbane when sitting at traffic lights.
    Usually hovers around 104.
    07 GTI
    APR stage II
  6. #96
    Jun 2007
    Eastern Suburbs Melbourne
    I'm running 40's, i'm ure a 45 ould be too large of a rolling diameter?
    i like volkswagens
  7. #97
    205x40x17
    They are approx 25mm larger dia than the 195x50x15's I currently have. I think the 17s fill the wheel arch better and the speedo should give a much more accurate reading with the bigger wheels. The Aussie MK2's have a speedo that's out by about 5%. When mine shows 100 ks it's really doing 96 with the 15's.
  8. #98
    Jul 2005
    The oil cooler not only cools the oil but the water helps to warm the oil up faster when its cold.
    Widebody Cayman S Turbo, 83 ur Quattro
    2000 996 C4 cab,12 Scirocco R OEM+ STG2+
    72 914 (3.2S boxster pwr), 92 G60 Corrado
    76 Scirocco(TFSI and DSG) 2018 Tiguan,Eureka,81 924.
  9. #99
    May 2010
    braidwood n.s.w
    paul.you know we got alot of work to do getting you heater fixed up and that motor you droped off at my place on thursday night.then we got go and see matey about his audi a4 but we can give him a call and see when its a good time see him.
  10. #100
    Jan 2007
    Reminds me, I've got a new heater matrix to install at some stage.
    07 GTI
    APR stage II
