Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Blew the motor in My Mk2. Conversion now underway.
    syncro Guest
    It starts, runs for 5 seconds and then dies. Sounds ok though. I suspect wiring or vacuum.
    Check that the fuel pump relay is connected properly.
    There are two feeds, start and run.
    Camden, Sydney
    Thanks for the tip syncro, my car has a hard wire that starts the pump. Perhaps the ecu recieves a signal back from the pump relay?
    I had a 16v that did this run for 5 seconds before dieing. I hadn't connected the vac pipe to the servo. A big air leak basically, the car was running on the fuel from the cold start injector, which runs for a short time.
    There wasn't a big whistling noise to give away the disconnected pipe or I'd
    have found it sooner.
Similar Threads
  1. Mk1 Commodore Caliper, 278mm Magna rotor conversion
    By golfnutracing in forum VW Watercooled Media Lounge & Interesting Articles
    Last Post: 06-06-2011, 04:23 PM
  2. Brake conversion
    By rayray086 in forum Mk3 Golf & Vento
    Last Post: 28-11-2006, 11:32 PM
  3. mk1 vr6 conversion?
    By glf-mk1 in forum Mk1 Golf
    Last Post: 08-02-2006, 01:52 AM
