Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 48
Thread: Bigt's Big MK 2 project temperature problems.
    I believe their is 3 temp sensors on the engine. I have had starting problems with my car for a while but took it german automotive in geelong who was very helpful and found it was the other two sensors (i had already replaced the blue one)
    Car runs sweet now
    Velly
    '91 2.0 8v GTI
    Quote Originally Posted by DubSteve View Post
    I have wood thinking about you
    Nov 2009
    dandenong,victoria
    Will give that a whirl, plus the tuning and digifant rundown procedure and check my throttle switch which is what
    the esteemed boys in the uk forum believe.
    Wish me luck !!!!!!!!!!!!!
    Quote Originally Posted by bigt View Post
    that was trhe other thing, the throttle switch was also an issue on my car too.
    fingers crossed!
    Velly
    '91 2.0 8v GTI
    Nov 2009
    dandenong,victoria
    All sensors are fine, ecu has continuity on all pins; tested whether switch wiring is ok thru to the ecu, it is.
    idle switch is clicking like a champ, sensor is doing what it should.
    Timing set to factory 6deg BTDC, O2 sensor replaced, all wiring replaced to the sensor, battery new, bottom end new,
    STILL NOTHING!!!!
    WTF is with this thing guys?? PIA to do all that and still get this cutting out....
    Engine code for bottom end is 2E, 1990 golf gti built 08/90. If this helps anyone out there.....
    Nov 2009
    dandenong,victoria
    Also all earth wires replaced and checked against the -tive of the battery and are tip top.
    So rule that out aswell
    does it restarts once it dies? is the engining turning and firing?
    Velly
    '91 2.0 8v GTI
    Jul 2005
    Newcastle, NSW
    Nov 2009
    dandenong,victoria
    Hey yea once it dies, I can turn it back over. Once I turn it back over it splutters and idles for a little bit then dies again.
    Thanks for the manual link, but I already have been using it at nauseum....
    Will try the relays and the main pump inside the tank to see whether its fueling properly.
    Thanks again
    May 2010
    NQ
    When it dies, what does the tacho do/show?
    Just falls to zero or does it bounce around wildly?
    MK2 - *Insert list of dealer purchased extra's/standard features here*
    80 series - The MK2's BIG, Sooty, polar opposite...
    HAHAHA
    Nov 2009
    dandenong,victoria
    Starts losing revs initially then dies.. And if you try and accelerate it does not have any "go".......
