Results 1 to 10 of 17
Thread: bent aerial help
    May 2006
    bent aerial help
    i was reversing at school last week and the aerial got caught on a overgrown tree, it bent the aerial like 45degrees ......how can i fix ? do i need the aerial if i have a different deck anyway ?
    May 2006
    c'mon guys any help here..where can i get a replacement aerial and is it neccesary to have if i have a new head unit ?
    syncro Guest
    What sort of aerial is it?
    Roof or mudguard?
    If it is the standard mudguard aerial, it is very easy. Take out the tyre, remove the mudguard lining, just a few screw. Then you can access the nut that secure the aerial, go to any auto-parts shop to get a similar one and put it back in. I did the same 6 months ago.
    If it is roof type, I can't help
    syncro Guest
    I tried for months to get one from a spare parts shop and couldn't get one as the VW ones are smaller.
    I may have one at home.
    syncro Guest
    Drilling holes in roof = rust.
    Reception is **** too.
    Jun 2006
    Rotorua new zealand
    i got a stubby bsting
    May 2006
    Brian Patterson has some I think. 02-9653114
    Quote Originally Posted by syncro View Post
    Can't say this will be an issue if done correctly.
    I've had bee sting aerial's in all my car's incl. my mum's current mk2 & have never had rust issue's in over 10 year's & if the power supply is O.K. you should never have a reception issue either. (Note all the aerial's have been the long bee sting version)
    Once the hole is drilled (without going straight through into the headliner), clean up the hole swarf & apply some paint to the bare metal, then I packed the underside of the aerial & seal with grease.
    Bingo.
    syncro Guest
    Mine rusted Was done by previous owner.
Similar Threads
  1. Bent color concept. Need help
    By ScienceVR6 in forum Wheels & Suspension
    Last Post: 26-02-2007, 08:40 AM
  2. Bent rear stub axle
    By gumbootracing in forum Mk1 Golf
    Last Post: 01-11-2006, 02:32 AM
