Page 6 of 13 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 127
Thread: Beaten down by a Nova.
  1. #51
    Camden, Sydney
    WOW. This thread heated up a bit huh?
    My coments with regards to spydas car was that with the chip and no other work done, its probably throwing in too much fuel and thus getting poor fuel economy and going slower.
    If you put a Mk3 downpipe and manifold and maybe a cam, it would be a different car. I have done it to a few aussie ones and it fixed em!
    I`m not gonna go there with your comments Ian, but you are wrong in so many ways. the UK cars were more powerful and faster. end of
    Also a Mk1 with the same engine would munch your mk2 all day.
    Enjoy the dub you have, no knocking others efforts or desires, lets keep this a nice place to be.
    I fully support the sensible comments of Pete Jones.
    Peace my VW Brethren
  2. #52
    Sep 2007
    Quote Originally Posted by Spyda View Post
    The argument about 8v and 16v is stupid and i havnt realy looked in to it. As far as i know and 8v needs alot of work and money to make 180hp, a 2l 16v needs KR cams to make 180hp. Mrgolf said "But a tuned 8V such as mine offered better low down torque meaning you didnt have to row through the gears as much to get the performance." That is probly true but wouldnt a 16v have more torque anyway, so regardless of where the torque is thourgh the power band, the tuned 16v has more. If a tuned 8v has 150nm at 3000rpm and a max of 160nm, wouldnt a tuned 16v with 190nm have about the same at 3000rpm?
    i'm with golf loon and pete on this one. a 2.0 bottom end, cams and mk3 zorst/extractors would do wonders for your car.
    the 16v is a completely different story. it's soo peaky compared to the 8v. but yeah. i have 8v love. i think also cause the valvers run the close ratio gear box, the needing to shift is probably down to ratios, rather than outright torque.
    good luck with the motor spyda. should be great fun with those few bits and pieces
    87' MK2 GTI
    13' MK7 TDI
  3. #53
    Oakleigh VIC
    I'll be writing up the 2.0 bottom end swap into a MK2 K-Jet system to replace a notoriously (and track proven by myself) underpowered GX 1800 bottom end. (This Mk2 motor is in a MK1). I'll be re-using the MK 2 K-Jet head and injection system.
    You might like to keep an eye on what I'm up to, there's a few little tricks along the way to sort out. I've got most of it figured out now, I'll write it all up as I do it , rather than link to third hand experiences, I'll write my first hand findings. Doesn't seem too hard, there's some fiddly bits but they can be overcome with off the shelf solutions if you're not up to the home brew challenge.
    I'm not sure how well this will work, although I'm confident it will work better than the low compression GX bottom end.
    It's a low risk gamble for me because I got the 2.0 engine very cheap and I can do all the work my self. Mostly this particular conversion will cost me time and gaskets. I plan to properly engineer a higher performance race motor next year after I've paid for a USA Holiday.
    Meanwhile if you have any questions - fire away and I'll explain the theory as I understand it before I put it into practice.
    Pete
  4. #54
    May 2006
    byron bay area
    Smile
    Actually I am not wrong I am just stating facts that people have a lot of problem wrapping their heads around or are just to plane thick to read what I have written
    I keep saying that off the mark the digi does not stand a chance, but in the top end in a real life driving situation the digi will take over every time
    Remember that a company like VW only would move away from kbasic because they had something better
    Its like you people are obsessed with living in some kind of myth
  5. #55
    Speechless although if this thread proves one thing it's that matt needs to bring another bunch of 8v's in his nect container perhaps....
  6. #56
    Jun 2007
    Perth
    x2 here... I use the word 'gay' quite a lot, and even did so with gay flatmates. Gay people tend not to have a problem with it.
    Quote Originally Posted by aliasmk2 View Post
    As for mrgolf,what can I say???????????????????????????????
    I am not the first person to use the term gay in a joking style of expression on this forum & I hope I won't be the last
    I have gay fiends & have worked with a lot of gay people who are evolved to the stage where they can openly joke about themselves, the same as a lot of Italian people take pride in the term wog
    Now do you get that!!!!!!!!! or are you not at that level yet
    Homophobic , I don't think so
    You really need to have a good look at yourself mate
    RIP Ruby Thunder (1994 VR6), now driving the GF's MK IV 1.6
  7. #57
    Canberra
    Ummm... no. They moved away from K-Jet because digi was more efficient. And digi helped with emissions more. And in the euro spec digi motors, you are probably correct in that the in gear acceleration is pretty good and at least on par with K-Jet. Where you are horribly, horribly wrong is where you reckon the Australian digi engined cars are better than the euro engined cars in gear. No. Just no. 112bhp vs 90-95bhp with less weight by around 100kgs will always mean the euro engined cars will be faster. Dont even get me started on torque differences... Having driven both on numerous occasions I can testify that the euro motors are faster everywhere. The reason for the power differences lie in the head and larger valves as well as extra emissions controls, not just the injection.
    As stated before, your experience may have been influenced by poor setup or, more likely, an overdrive gearbox whose 5th gear was a lot taller than the genuine GTI boxes. This would result in slower in gear acceleration. If you had driven a euro specced MkII GTI with an EV, you would be more qualified to make such a statement. As you arent, you would have to admit that your experience isnt extensive enough to make a categoric statement as you have.
    No offence meant, though, mate. And I have had a good hard look at myself, and I am comfortable with what I see. Especially since I have addressed this arguement far less emotively than yourself. Its only a forum, and its full of opinions. But opinions arent fact until you back them up with hard data/ evicence.
    Euro look 2... Mk2 love!
  8. #58
    Feb 2007
    I was thinking on the train about the mk3 downpipe and mainfold with cams and a 2L bottom end. It realy wouldnt be a bad base. It would open up the mk2 as you all say and would be cheap.
    Pete I will be watching
    MK1 GLS 3door
    A4 B7 2.0T
  9. #59
    Sep 2007
    mm.. i think we need to transfer some of the more relevant/useful ideas to a thread entitled - "how to make 8vs awesome!"
    2.0 would be a good base. but i reckon i'd go cams before i went 2.0 bottom end. nothing extreme, just a bit more lift, bit more duration. oh and definately the mk3 manifold/downpipe. have you ever seen the mk2 aussie downpipe? it looks like some kind of deformed urinal.
    87' MK2 GTI
    13' MK7 TDI
  10. #60
    Feb 2007
    Quote Originally Posted by jayjay View Post
    Do you think that would be a good idea without the mk3 manifold and downpipe?
    I thought it would have been better to do the mk3 mani and downpipe first as that is the main restrictor (i have been told) then put a cam in to make use of that extra exhaust flow as air flow in to the engine has already been improved a little, then increase displacement to get a bit of extra torque.
    I have read you wont get much power gains from a 2L but torque gains will be noticable. Then to unleash the 2l a bit more get the head ported and get a 4branch mani and full exhaust. Pump more fuel in with a higher presure fuel reg and some bigger injectors, maby from a g60. And then when that is done you get bored of it and put in a vr6 with SC, after you win the loto.
    MK1 GLS 3door
    A4 B7 2.0T
