150hp from a counterflow 8v is a tall order without porting is a pretty big ask.
you wont need a different ecu at all. golfloon never said anything about needing a new ecu.
you also wont be able to increase compression ratio very easily... first things first. mk3 gl (thanks matt) exhaust manifold and a g-grind/neuspeed/lumpy-ass cam will make quite a reasonable difference. then if you're not
-ing enough, worry about the others.
edit:
note - most of these guys are using the gl 2L bottom end, have bigger cams and are running them in 200kg lighter mk1s.
