I believe you can do it the other way too. I siliconed mine as I bolted them together, and the fact that you have to remove silicon from the mounting surfaces after pulling them apart from the original factory assembly would suggest that they dont dry assemble and then silicon... Mine pushed the silicon out the edge where it was spread as a bead around the rim. A mate who works at a wheel repair shop helped me with them.Originally Posted by dubstar
Nice wheels, though. I think they are almost the same dimensions as mine. I heart RS...
