Results 1 to 4 of 4
Thread: GTI master brake cylinder replacement.
    Feb 2007
    Damn roadworthy,
    (Golf Mk2 GTI 8v 1990)
    The master brake cylinder needs to be replaced, cant i be replaced with a SEAT cordoba one?
    There will probably be more things I will be asking. Damn roadworthy to hell!
    *More*
    I need the drive shafts to (if thats what there called on a FWD). Both sides, can they also be taken of a SEAT Cordoba?
    Does anyone know where i can also get a windscreen for the mk2?
    Thanks guys.
    MK1 GLS 3door
    A4 B7 2.0T
    Camden, Sydney
    What year Mk2? Is it an Aussie one?
    Drive shafts from a Cordoba are the same.
    Master cylinder from Cordy will work, but may not have the same number of outlets. It does have T piece brake line splitters so you could use the whole line with them attached.
    Brake Booster from Cordy wont work, the inner end is different.
    I have a Mk2 booster here if you get stuck.
    Feb 2007
    Thanks mate, ill let you know.
    The GTI is a 1990 german one.
    MK1 GLS 3door
    A4 B7 2.0T
    Penrith, NSW
    Quote Originally Posted by Spyda View Post
    Member "qsz" is wrecking Mk2, not sure if windscreen is available still but might be worth giving him a PM to check, is in Melb by the way.
    1986 MkII Golf GTI 16V (Sold), 2005 MkV Golf GTI (Sold), 2007 Polo GTI (Sold), 2011 Polo 66TDI (Selling), 2012 Passat 125 TDI Bluemotion, 2013 Scirocco R (Due October!)
