Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
Thread: Auto Problems
  1. #21
    North Sydney
    I had the same problem with a manual. The revs would jump about at the lights dipping down to 500rpm and up to 1500rpm and occaisioanally stalling. I only got it fixed last week. An auto electrician fixed it for $400. Not too sure what was wrong as I got my dad to take it in for me, and I haven't seen him to pick up what the guy wrote down the problem is. Only thing is now the trip computer doesn't work.
    Hello too btw, first post and all, been a bit of a lurker. I got a 92 GTI 8v, 4 door.
  2. #22
    syncro Guest
    Quote Originally Posted by Yoshi Boom View Post
    Check the vacuum hose behind the speedo.
  3. #23
    May 2006
    byron bay area
    It moght be a good idea to check the vacume T-peice that sits just behind & to the left of the inlet manifold & any other vacume lead that you can find.
    My car has had problems similar to this & has been fixed easily when the lead is put back on, this can also play havic with MAF.
    So does your MAF give accurate readings, one day I was getting bizzare readings for my feul econemy & it was because one of the vacume leads was detached.
    So it really does sound like a fuel or electric problem & not transmision
  4. #24
    May 2006
    byron bay area
    Welcome to the forum,we need more mk2's !!!!!!!!
    what is your location?
  5. #25
    North Sydney
    Hello, Thanks for the Vacume piece advice, I will check it out. The display shows that I have done 2705kms (this does not change), and a trip time of 63:55 and climbing each time I start (No reset). Fuel consumption is stuck on 8L.
    It turns out that that $400 figure was for getting the central locking, windcreen wiper switch and system EC fixed. The rev problem was fixed in the 10,000 km service which only cost me $160.
    As for location, I am in Sydney in the lower north shore. I see a couple of mk2's around here, do any belong to forum members?
