Results 1 to 4 of 4
Thread: Audi adr into mk2
    Feb 2009
    NSW
    Audi adr into mk2
    Hi guys,
    Swapping in an adr into the Mk2, what exhaust manifold do I use? All the info I can find is on the 20vt. This is the Na 20v. Also what mounts will I need?
    Thanks in advance.
    Sent from my Pixel 2 using Tapatalk
    nsw
    I truly dont know but I can tell you that I was surprised to see that the 2.0L TFSI motors eg mk 5&6 Golfs has the same port spacings on their exhausts as the 1.8T 20V. So for example with an adapter plate (cos the studs are different) I can fit one of those turbos to my 1.8T. Makes me think the NA 2.0L FSI motors (ABF?) would probably do the same and may not even need an adapter as they are only 1 generation removed from the 1.8T.
    nsw
    VW Mk1 20V branch manifold - Evolution/STO/MRCtuning
    I'd also check out some of the south african forums. They had a one spec Cup race series there in the mid 2000's using 9N Polo's. The engines were normally aspirated with 2.0L blocks (ABF maybe?) but with 1.8 20V heads. If anyone was to know about proper NA exhaust manis for 1.8 20V heads in transverse config it'd be them.
    Feb 2009
    NSW
    Thanks. I'll hit them up!
