Results 1 to 10 of 45
Thread: Arrrggh!!! Jetta!!!
Rednut Arrrggh!!! Jetta!!! 21-07-2006, 06:25 PM
worm The saga continues... 21-07-2006, 06:29 PM
Rednut MOLLINS TO THE RESCUE :D ... 21-07-2006, 06:56 PM
evorobin What was I saying about... 21-07-2006, 08:00 PM
Rednut i dunno but i wish the jetta... 21-07-2006, 08:06 PM
Golf Loon Aaaaargggghhh. That car is... 21-07-2006, 08:11 PM
Golf Loon See if mollins has some gear... 21-07-2006, 08:12 PM
Rednut yep. we've already organised... 21-07-2006, 08:30 PM
Guest If its only the linkages why... 21-07-2006, 10:00 PM
Golf Loon I`d jam it in a gear and get... 22-07-2006, 09:51 AM
worm lol..... i hope this car is... 22-07-2006, 01:36 PM
Guest Exorcism required:evil: 22-07-2006, 05:55 PM
Rednut The Boys Have Done It!!!! 22-07-2006, 07:29 PM
Golf Loon Nice. Glad it had a happy... 22-07-2006, 07:33 PM
Golf Loon And a big cheers to Mollins... 22-07-2006, 07:36 PM
GoLfMan good stuff boys, thats what a... 22-07-2006, 08:26 PM
evorobin Great write up. I've had a cv... 22-07-2006, 09:06 PM
GoLfMan Amen ;) Scuse the pun 22-07-2006, 09:22 PM
Rednut its definately gone through a... 22-07-2006, 10:10 PM
mollins glad we could help out...... 23-07-2006, 05:33 PM
Golf Loon Go the newy golf crew. I... 23-07-2006, 05:45 PM
mollins mmm... cruise :D the CV... 23-07-2006, 05:53 PM
Rednut do ya blame me :P 23-07-2006, 09:00 PM
Golf Loon I`m so glad it had a happy... 23-07-2006, 09:12 PM
Rednut theres always the other cv... 24-07-2006, 10:31 AM
Rednut rear suspension 25-07-2006, 09:33 AM
mollins i may have some spare... 25-07-2006, 10:15 AM
Golf Loon It has cut springs, I have... 25-07-2006, 06:30 PM
Guest Are Jetta springs the same? 25-07-2006, 06:32 PM
Golf Loon As Mk2 Golf, Mk3 and Cordoba.... 25-07-2006, 07:35 PM
Guest Only guessing I thought the... 25-07-2006, 08:27 PM
Guest Jetta rears would have to be... 25-07-2006, 10:30 PM
Golf Loon How about we split the... 25-07-2006, 10:34 PM
Rednut *shrugs* im far from giving... 10-10-2006, 03:08 PM
ausgolfer Sounds like the hydraulic... 10-10-2006, 03:32 PM
Rednut cheers mate, i'll check it... 10-10-2006, 03:49 PM
ausgolfer Every 5 seconds? hmmm... 10-10-2006, 04:22 PM
Guest Lifter/tappet 10-10-2006, 04:42 PM
Rednut it had an oil change just... 10-10-2006, 04:58 PM
joshyd-mk2gti sounds like the tappets or... 10-10-2006, 05:37 PM
aliasmk2 lifters 10-10-2006, 06:20 PM
    Jul 2005
    Melbourne, Williamstown
    Quote Originally Posted by Rednut
    i just warmed her up cause the old man is taking me from a drive.. and the engine now ticks with the idle.. i presume this is bad.. the sound is similar to flicking a playing card.. i cant pinpoint where its coming from but it sounds like its coming from the head or the block..
    any ideas?
    Sounds like the hydraulic lifters/tappets sticking. People recommended to me to run about a litre of Auto transmission fuild in with the oil for a few hundred kms before you change the oil to clean them out(driven softly). I tried this and didn't notice much of a difference. I recently put up a post about rebuilding your hydraulic lifters, think it was in the restoration section.
    Hope this helps.
    mk2 GTi 16v
    Corrado G60
    Maitland, NSW
    cheers mate, i'll check it out.
    the clicking is about 5 every second.. but its softer now.. or the engine got louder.. i'll see how it goes.. it still needs a serious tune up. i'll keep ya'll posted
    2.0L 6 Speed Mk3 2015 Skoda Octavia vRS 220 Wagon - Current
    2.0L 6 Speed Mk5 2005 Volkswagen Golf TDi - goneski
    2.0L 5 Speed Mk1 1995 Seat Toledo - goneski
    1.6L 5 Speed Mk2 1990 Golf - goneski
    Jul 2005
    Every 5 seconds? hmmm different, could be a belt or something, or even the sound of a loose spark earthing out, but otherwise thats got me beat.
    mk2 GTi 16v
    Corrado G60
    brackie Guest
    Lifter/tappet
    Guaranteed that's the problem. It should go away with time. If it doesn't do what Ausgolfer suggested but remember to drive carefully and change the oil when the noise goes. (ATF will tend to evaporate form the oil anyway.)
    Maitland, NSW
    it had an oil change just before it went back to the loons workshop. it ticks about 5 "per" second i should say
    i just drove it round for the past hour and she went fine.. the old man reakons im ready to get my p's.. lucky he didnt get me to do a few parks.. i cant remember the last time i had to park other than drive into the carport
    few more hours and i'll be joinin the cruises.. weeee!
    Aug 2005
    Prahran, Vic
    sounds like the tappets or the oil might be low..? go to supercheap and get some stuff to put in the oil to fix the tick, theyve got a few different brands of stuff. does anyone know if you can buy Sea Foam overhere? the yanks rave about it. you can put it in the oil, suck it in the intake through a vacuum hose or put it in the fuel tank and it cleans all the carbon and crap out of the engine.
    May 2006
    byron bay area
    lifters
    it does sound like the lifters & it would be one ofthe more common noises that a vw would make
    i don't like to use additives in the oil,
    what i have noticed is that a long & not to easy drive is a sure way of fixing this, but make sure that you have eneogh oil as that could be the overall cause
    also it does seem to show up more often when the car is not driven very much or goes very short trips
    either way it is not to much to worry about as long as you check your oil
    good luck
    Camden, Sydney
    Has the car been sitting around??
    You need a decent drive to get the oil pressure up.
    When engine is warm, rev the car at idle to 3000 rpm and hold for a few seconds. Do that a couple of times and tap nise should go away. Thats lifter noise, because the oil has all drained out of them into the bottom of the engine.
    Sounds like you are nearly ready for Ps. Exciting. We`d love to see the Jetta on a Cruise again
Similar Threads
  1. Jetta FSI Turbo
    By tofo17 in forum Mk5 Golf & Jetta
    Last Post: 04-05-2008, 07:44 PM
  2. Jetta TDI - First Impressions
    By vectorskink in forum Mk5 Golf & Jetta
    Last Post: 04-02-2007, 07:59 AM
  3. Jetta arrived (finally)
    By LS1 Cobra in forum Mk5 Golf & Jetta
    Last Post: 29-12-2006, 09:42 PM
  4. No TDI Badge for Jetta
    Last Post: 04-10-2006, 10:18 PM
  5. jetta jetta jetta
    By Rednut in forum Mk2 Golf & Jetta
    Last Post: 11-02-2006, 01:38 AM
