Results 1 to 10 of 45
Thread: Arrrggh!!! Jetta!!!
    Maitland, NSW
    do ya blame me
    2.0L 6 Speed Mk3 2015 Skoda Octavia vRS 220 Wagon - Current
    2.0L 6 Speed Mk5 2005 Volkswagen Golf TDi - goneski
    2.0L 5 Speed Mk1 1995 Seat Toledo - goneski
    1.6L 5 Speed Mk2 1990 Golf - goneski
    Camden, Sydney
    I`m so glad it had a happy ending.
    That CV is probably one of the few bits of that car that have not been changed.
    Maitland, NSW
    theres always the other cv joint...
    Maitland, NSW
    rear suspension
    the jetta is still bottoming out even with 2 people in the car.. i looked under the car yesty and found that the spring on the left side is disturbingly close to the wheel.. it looks as if the wheel would hit the spring when it goes up.. it seems a bit far to hit the guards or the roof of the arch?? i'll check the other side this arvo after work to check if its the same on the other side.. altho it only seems to bottom on the left side.
    i cant exactly move the springs can i? any ideas on a temp fix.. nonety $ to buy new suspension.
    Loon, what springs are on it, do you know?
    cheers
    Nov 2005
    newcastle
    i may have some spare springs... are the rears of a mk2 same as a mk1?
    TDI mk1 on the road!!
    Camden, Sydney
    It has cut springs, I have some stockers you can have if the newy crew want a job. Not the same as Mk1
    syncro Guest
    Are Jetta springs the same?
Similar Threads
  1. Jetta FSI Turbo
    By tofo17 in forum Mk5 Golf & Jetta
    Last Post: 04-05-2008, 07:44 PM
  2. Jetta TDI - First Impressions
    By vectorskink in forum Mk5 Golf & Jetta
    Last Post: 04-02-2007, 07:59 AM
  3. Jetta arrived (finally)
    By LS1 Cobra in forum Mk5 Golf & Jetta
    Last Post: 29-12-2006, 09:42 PM
  4. No TDI Badge for Jetta
    Last Post: 04-10-2006, 10:18 PM
  5. jetta jetta jetta
    By Rednut in forum Mk2 Golf & Jetta
    Last Post: 11-02-2006, 01:38 AM
