Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 45
Thread: Arrrggh!!! Jetta!!!
  1. #21
    Camden, Sydney
    Go the newy golf crew. I smell a cruise in the air
  2. #22
    Nov 2005
    newcastle
    mmm... cruise
    the CV was well and truely jiggered... as soon as we pulled the boot back out came a rain of chunks of the dished washer, a lot of glittery grease and all the balls (hence the commando roll)... the splines on the driveshaft had been all bent too so we couldnt get the old CV off... so we ended up using a spare shaft from my shed... rednut was smiling so much he was about to bust his cheek bones when we backed it out of my driveway... made it all worth it haha
    TDI mk1 on the road!!
  3. #23
    Maitland, NSW
    do ya blame me
    2.0L 6 Speed Mk3 2015 Skoda Octavia vRS 220 Wagon - Current
    2.0L 6 Speed Mk5 2005 Volkswagen Golf TDi - goneski
    2.0L 5 Speed Mk1 1995 Seat Toledo - goneski
    1.6L 5 Speed Mk2 1990 Golf - goneski
  4. #24
    Camden, Sydney
    I`m so glad it had a happy ending.
    That CV is probably one of the few bits of that car that have not been changed.
  5. #25
    Maitland, NSW
    theres always the other cv joint...
  6. #26
    Maitland, NSW
    rear suspension
    the jetta is still bottoming out even with 2 people in the car.. i looked under the car yesty and found that the spring on the left side is disturbingly close to the wheel.. it looks as if the wheel would hit the spring when it goes up.. it seems a bit far to hit the guards or the roof of the arch?? i'll check the other side this arvo after work to check if its the same on the other side.. altho it only seems to bottom on the left side.
    i cant exactly move the springs can i? any ideas on a temp fix.. nonety $ to buy new suspension.
    Loon, what springs are on it, do you know?
    cheers
  7. #27
    Nov 2005
    newcastle
    i may have some spare springs... are the rears of a mk2 same as a mk1?
  8. #28
    Camden, Sydney
    It has cut springs, I have some stockers you can have if the newy crew want a job. Not the same as Mk1
  9. #29
    syncro Guest
    Are Jetta springs the same?
  10. #30
    Camden, Sydney
    Quote Originally Posted by syncro
    As Mk2 Golf, Mk3 and Cordoba. Yes.
    Not same as Mk1
Similar Threads
  1. Jetta FSI Turbo
    By tofo17 in forum Mk5 Golf & Jetta
    Last Post: 04-05-2008, 07:44 PM
  2. Jetta TDI - First Impressions
    By vectorskink in forum Mk5 Golf & Jetta
    Last Post: 04-02-2007, 07:59 AM
  3. Jetta arrived (finally)
    By LS1 Cobra in forum Mk5 Golf & Jetta
    Last Post: 29-12-2006, 09:42 PM
  4. No TDI Badge for Jetta
    Last Post: 04-10-2006, 10:18 PM
  5. jetta jetta jetta
    By Rednut in forum Mk2 Golf & Jetta
    Last Post: 11-02-2006, 01:38 AM
