Page 5 of 5 FirstFirst ... 345
Results 41 to 45 of 45
Thread: Arrrggh!!! Jetta!!!
  1. #41
    May 2006
    byron bay area
    lifters
    it does sound like the lifters & it would be one ofthe more common noises that a vw would make
    i don't like to use additives in the oil,
    what i have noticed is that a long & not to easy drive is a sure way of fixing this, but make sure that you have eneogh oil as that could be the overall cause
    also it does seem to show up more often when the car is not driven very much or goes very short trips
    either way it is not to much to worry about as long as you check your oil
    good luck
  2. #42
    Camden, Sydney
    Has the car been sitting around??
    You need a decent drive to get the oil pressure up.
    When engine is warm, rev the car at idle to 3000 rpm and hold for a few seconds. Do that a couple of times and tap nise should go away. Thats lifter noise, because the oil has all drained out of them into the bottom of the engine.
    Sounds like you are nearly ready for Ps. Exciting. We`d love to see the Jetta on a Cruise again
  3. #43
    Maitland, NSW
    yeh.. i sit her at aobut 2500 for about 2mins.. then its ready to idle.. hehe. i turned it over a few times today and it took less and less time. should be sweet once im regualarly using it. i dont remember hearing the noise at the servo today.. so its probably all good now. it didnt bottom out which was suprising.. altho i was taking it alot easier with the oldman in the car
    but then again, im no leadfoot(yet) like my older sibling.
    i think a tune and a quote about fixing the suspension so it doesnt bottom will be first on the pit list.
    i'll get the quote and see what ya'll think.
    2.0L 6 Speed Mk3 2015 Skoda Octavia vRS 220 Wagon - Current
    2.0L 6 Speed Mk5 2005 Volkswagen Golf TDi - goneski
    2.0L 5 Speed Mk1 1995 Seat Toledo - goneski
    1.6L 5 Speed Mk2 1990 Golf - goneski
  4. #44
    Camden, Sydney
    I still have struts with springs in sitting next to the garage, ready to send up to you. They should make your car stock height and tou can fit em in an hour or less. I`ll try and box em up this week.
  5. #45
    Maitland, NSW
    hmm.. stock looks a bit too american for my liking.. i'll investigate it later when it starts scrapeing again. i think the tuneup will be first.
Similar Threads
  1. Jetta FSI Turbo
    By tofo17 in forum Mk5 Golf & Jetta
    Last Post: 04-05-2008, 07:44 PM
  2. Jetta TDI - First Impressions
    By vectorskink in forum Mk5 Golf & Jetta
    Last Post: 04-02-2007, 07:59 AM
  3. Jetta arrived (finally)
    By LS1 Cobra in forum Mk5 Golf & Jetta
    Last Post: 29-12-2006, 09:42 PM
  4. No TDI Badge for Jetta
    Last Post: 04-10-2006, 10:18 PM
  5. jetta jetta jetta
    By Rednut in forum Mk2 Golf & Jetta
    Last Post: 11-02-2006, 01:38 AM
