Page 7 of 7 FirstFirst ... 567
Results 61 to 64 of 64
Thread: Another GTI in Adelaide
  1. #61
    quick tip, when hanging freshly painted parts, find a secure source to hang them off. They left dimples in the concrete... lol
    8v Ibiza GTI > 8v mk2 Golf GTI > mk3 VR6 > 8v Ibiza GTI > 2D CL+vr6...
  2. #62
    Oct 2012
    NSW
    Quote Originally Posted by Johnm View Post
    Hey mate the car looks sick! I just got a white mk2 4door from Sydney (probably the one you were going to get) auto though. That fuel consumption sounds a little hectic. Mine sits at around 8l/100kms. Hopefully the gauge is out of wack. Good luck with it man! Keep us up to date with what you do to it!
    I own that white one now
  3. #63
    so i gave it a little run today and i noticed the fuel line to the filter is leaking fuel, im thinking the filter might be blocked and this could also be causing the fuel starvation/performance issue i had.
    Could the pump be pumping at that high pressure thru the clogged filter to be leaking past the hose?
    is there a way i can check the filter for flow?
    thanks
  4. #64
    Jan 2013
    Quote Originally Posted by hamza View Post
    thanks
    Whenever I change a filter, I tip the in port towards the ground and watch for the colour of the fuel coming out... usually brown.
    Its a 20+ year old car and its a part that is often neglected, change it out. I believe the mk2 also has 2 other filters (a pre filter in the tank and one somewhere near the engine bay?
