Page 6 of 7 FirstFirst ... 4567 LastLast
Results 51 to 60 of 64
Thread: Another GTI in Adelaide
  1. #51
    I checked the linkages and they shift fine, also checked the pedal box.
    Any other ideas? Anyone?
    Thanks
    8v Ibiza GTI > 8v mk2 Golf GTI > mk3 VR6 > 8v Ibiza GTI > 2D CL+vr6...
  2. #52
    Check this site out...Welcome to BrokeVW.com
    Its a little tricky to navigate through, but has all the info you need to find a solution to your problem. Well explained and lots of photos to make life a little easier. I used this when I had an issue with my Ibiza clutch. All sorted now...
    MK6 Golf GTI ///Adidas | 9N Polo GTI | 96 Seat Ibiza 8v GTI
    Quote of the day, from my wife.... "Stop washing your car... it's going to rain anyway"
  3. #53
    Jul 2005
    Melbourne, Williamstown
    Not saying it is but I had an issue where I couldn't engage/disengage gears while the motor was running. The clutch actuation rod had poked a hole clean through the plate that pushes on the clutch engagement fingers inside the box. I could change gears with the motor off but not when it was running.
  4. #54
    Thanks guys, AUSgolfer,
    How did you find that out? By seperating the box?
  5. #55
    Jul 2005
    Yes unfortunately had to take the box out. The box didn't have to come apart but had to separate from the motor.
  6. #56
    Yep thought so, well we spent about 4 hours trying to get the tranny out. Everything is unbolted just needs to be wiggled back and forth to get it out. We will hopefully get it out early tomorrow morning and inspect the disc and flywheels..
    ---------- Post added 08-05-2012 at 05:39 PM ---------- Previous post was 07-05-2012 at 06:05 PM ----------
    Well today didn't go to plan... Still haven't got the box out, I think the combination of Having every factory feature under the hood leaves very little space to breathe. I still can't believe how hard it is to work on this car, this is one of the reasons I still have my ta22...
    Me and dad almost decided to just drop the subframe down.. 5 times!!
    So I guess I will start early tomorrow morning and remove the aux items such as battery/washer bottle/coolant overflow/starter ect.
    This is the first car we have struggled to remove the transmittion for this long.
  7. #57
    Alright we got the box out and disassembled the clutch, can anyone see something wrong here? dad assumes its the clutch plate as it seems to be worn. The plate that activates the pressure plate dose have a hole thru it but the rod can't pass thru it.
    Also i don't see how the clutch being worn can affect me not being able to engage/disengage.
    So has anyone bought a clutch from germanautoparts.com? as far as i can see its the cheapest place to buy from just not sure about the postage costs.
    ---------- Post added at 04:00 PM ---------- Previous post was at 03:59 PM ----------
  8. #58
    Dec 2008
    Bentleigh, Melbourne
    yeah i've bought a genuine sachs clutch kit from them.
    if your buying stuff from them you should think of other things you may need in the future (if money is no issue), oil filters, service equipment etc.
    shipping costs aren't too bad, and i've always got the delivery within the week!!
  9. #59
    alright so the problem is that i have punched out a "rivet" that is in the centre of the disc.
    I have placed an order for a new heavy duty kit from gap.
    I also orders a set of the ATE premium discs, but they are out of stock and back logged, so my alternatives are x-drilled Zimmerman or standard. I have been reading up on the quality of Zimmerman discs and have had mixed results. Has any one used them and what ate your thoughts of them?
    I will be putting the car throu it's paces at mallala in mid sept so the car will se some track time and will be generally driven in a sporty fashion...
  10. #60
    So the new semi heavy duty clutch is in and i have got the parts necessary to do the brake conversion. I blasted the callipers and discs and they look like new. I would like to install new wheel bearings but cant wait till another package arrives from gap, called a couple of places and they seem quiet expansive considering mk3 golfs are plenty around.
    Painted the callipers red and still have to install the tie rod ends and do a minor service before the track day... Cant wait!
    what do you guys think of these wheels?
