Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Which Alternator fits.
    Camden, Sydney
    You can use the belt setup from a Mk3, which includes the AC compressor and power steer pump. You need all these parts from a Mk3. You could then get new ends put on your Mk2 a/c hoses and use the stronger Mk3 compressor.
    PM Peter Jones, he should have 2 setups from cars he has wrecked
    And he is in Melbourne.
    Feb 2007
    HAHA thanks man but it sounds a bit to much work for me and besides that im out of money.
    Ill see what i come up with using the mk3 alternator.
    If i cant fix it ill just drive the car till it catches fire, then get something that works and does 0-100 in less then 20min.
    MK1 GLS 3door
    A4 B7 2.0T
    Oct 2005
    Dandenong North, Vic
    Quote Originally Posted by Spyda View Post
    I its now over charging, 16+volts ?
    Have you replaced the voltage regulator ?
    MK2 GTI G60
    Feb 2007
    Quote Originally Posted by aussieg60 View Post
    I dont even know what that is , where is it and wtf?
    Im 3/4 of the way to fitting the new alternator, mmmm 90amps, just need to get my grinder back.
    MK1 GLS 3door
    A4 B7 2.0T
