Results 1 to 10 of 13
Thread: ah Crap we can't get Wilwoods :(
    Jun 2006
    Hornsby
    Dag nammit,
    they dont have dust seals! ah crap I am 50/50 on these there great value however I dont know if I can get through engineering.
    any thoughts
    Go oem. You staying 4 stud go 280
    Aug 2005
    Quote Originally Posted by evorobin View Post
    OEM calipers are better than Wilwoods anyway
    Jun 2006
    Hornsby
    Oem huh, as in the girlings? I managed to source a 22mm master cyl. as well so im set i just need some nice brakes. Yer im after 280mm corrado discs and then some form of caliper
    May 2006
    byron bay area
    I have a strong feeling that willwoods won't make the grade for road use here
    Girling 60's twin pots are the go with a 24-25mm master cylinder
    Aug 2005
    Quote Originally Posted by Valver. View Post
    Hey Valver, I am curious, what is wrong with Wilwoods (beside the dust seals). I know you have referred to them as 'show' brakes, is that due to maintenance or performance issues?
    Gosford Central Coast NSW
    dont ofrget the SEAT Cupra 16V disks and calipers are 280mm and bolt on aswell
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Camden, Sydney
    Yeah I have a set of the cupra carriers and calipers Tommy. You could keep it 4 stud and still have awesome brakes.
    Jun 2006
    Hornsby
    ah so many choices! i have a 22 mm master cyl so thats a start!
    Willwoods are a no go now
    ECS porsche brakes won't fit under my 15'' BBS
    AP racing won't either
    so that leaves me with the G60 or Ibiza Cupra brakes, I thought these where brembo 4 pots that ran a 12.3 inch disc ? or is that just the Cupra R ? Which again would not fit under a 15'' wheel or am i wrong?
    May 2006
    byron bay area
    A 22mm master cylinder will improve your pedal feel to start with
    You can the put on the mk3 hubs with the 256mm rotor which will take the cupra or girling 60 carrier/calliper if you are still not happy with the 256mm
    There are all sorts of rotors & pads for the 256mm brakes, which should give you heaps more stop than standard
