Results 1 to 9 of 9
Thread: After Market Thermo Fans
    Oct 2012
    NSW
    Hello..... I need to change the thermo fan on my GTI 8V, and from what I understand the original fan is a 2 speed.
    What i would like to ask is.... are the 3 wires running to the original fan = 1 wire-negative, 1 wire-stage 1, 1 wire 1-stage 2. If that is the case can I run 2 slime line Davies Craig fans? 1 setup for stage 1 and the other for stage 2?
    Thanks guys
    Apr 2008
    From what I remember the third wire is for the temp sensor?
    May 2010
    NQ
    You are spot on Herc
    Brown - Negavtive
    Red 1 - 12V + (Stage 1)
    Red 2 - 12v + (Stage 2)
    MK2 - *Insert list of dealer purchased extra's/standard features here*
    80 series - The MK2's BIG, Sooty, polar opposite...
    HAHAHA
    Oct 2012
    NSW
    cool..... I mean that literally lol... thanks
    May 2012
    you sure a slime fan is gonna be good for your motor?
    Oct 2012
    NSW
    not after reading your comment... No, I'm not sure now. I'll have to check the CFM now.
    May 2010
    NQ
    Quote Originally Posted by HercGTI View Post
    You will be fine.
    I'm using 2 cheap thermo's, without a shroud, A ok.
    You can get away without a fan, so long as you don't stop too often (I did it for 2 weeks)
    HAHAHA
    Oct 2012
    NSW
    thanks for that, I'll pick up 2 tomorrow from work.
    Oct 2012
    NSW
    works like a charm.... thanks for the help
