As far as i know the screw on the MAF adjust A/F ratio.
The o2 sensor should be replaced every 160,000ks acording to the bently manual.
The idel is set using the screws on the throttle body but it gets a bit complicated, to do it properly you have to unplug the blue temp sensor, the car will strugle but thats normal. Then you have to rev it past 3000rpm 3 times, each time letting it drop to idel. This lets the ECU know you have unpluged the blue bastard. Then you adjust the idel screw to 1000rpm and plug the temp sensor back in. You can then switch of the motor off and back on and it should idle at 850. All fiddling has to be done at running temp, 80 degrees or something. Just wait for the fan to turn on and you know your at the right temp.
If the idle is hunting its usaly the ISV, soak it over night in brake cleaner that is rubber friendly, rinse it out and let it dry fully.
Im not guna tell you that this will solve the problem because in my experiense the idle on a digi mk2 is a head fuk and you just gota try everything.
