Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: 85 mk2 gti
    Aug 2006
    Melbourne VIC
    I think we need some pics n spec of all these cars! ASAP
    Camden, Sydney
    Rocco pics, or ban.
    Mar 2008
    Wollongong, NSW
    here are some more pics of the mk2 (sorry no rocco at the moment). we took it for dyno tuning today. it made 148.6kW at the wheels on 14psi boost, but we had spark issues, so boost was brought back to 12psi where it made 137.5kW, still with the spark problem. the spark just wasn't strong enough above 4500rpm, and it will probably need coil packs. the old engine and smaller turbo setup previously made 138.4kW at the wheels on 14psi, apparently without spark problems. it'll be a while before it gets a new ignition and a run at higher boost, but for now 137.5kW will do. enjoy!
    Mar 2008
    Wollongong, NSW
    more photos!
    Very nice indeed. Are you bringing it to the nats this year?
    Quote Originally Posted by Whubbsie View Post
    There is nothing better than a polo badge, thats why you will notice Veyron drivers with polo gti badges.... they know where the true sizzles at!
    Aug 2006
    Melbourne VIC
    Good to see another VW pulling some numbers and kepping the VTECH in the mirror
    Jan 2007
    Nice !
    Red on red is timeless!
    07 GTI
    APR stage II
    Feb 2007
    Love It!!!!
    MK1 GLS 3door
    A4 B7 2.0T
    Jan 2007
    [QUOTE=richo;145549] it made 148.6kW at the wheels on 14psi boost, but we had spark issues, so boost was brought back to 12psi where it made 137.5kW, still with the spark problem. the spark just wasn't strong enough above 4500rpm, QUOTE]
    What sparks you using?
    I have good things about the Bosch platinums with the 4 prong tips.
    just a thought..
    07 GTI
    APR stage II
    Jun 2006
    Orange NSW
    I should explain that this tuning is just for running in the new internals aswell so the tuning is for a safe power figure with a lot more ijnition retardation than used previously. When i save up i will get 4 idividual performance coil packs mounted directly on top of the spark plugs and change the hall sensor aswell. The combustion pressures blow out the spark above 4500rpm even though the spark gap was set to 0.6mm and upon testing the coil it was found to be on the way out. The ihi vf22 turbo has its sweet spot of between 18 and 22 psi and tuner was very confident that with the ijnition sorted and running 20psi or so it will make an easy 180 plus kw at the wheels and may top 200kw at the wheels. Ill get this done before the nats i hope!
