what prefix audi motor?
and a 2.0 head on a 1.8 block will generaly lower compression...
hi dubbers, cheers for the info on my airflow sensor, scored one from europarts and its on its way. will an audi block 2l 1991 go into my mk2 gti 8v ? i may have read a thread here in the past but could anyone give me an insight, as ive got my hands on a bargain car !! thanks
Cheers, Benny
www.axesent.com.au
The 2L has bigger intake ports so you would need to use a the audi manifold, but it comes out the wrong side, so you`d need a mk3 one which has a different throttle body. So not a straight bolt on. Better to use the 2L bottom end and your 1.8 head. Bolts straight in and is rapid.
so that ,would i assume give me more power ?
the audi is a 91 model , joe says there is alot of variations wth a 2 l block , yesterday i set the air flow meter a few clicks and it made a good improvement . i will go for the engine swap with the 2l and i got a set of leather vr6 seats to and tear drop alloys , just need to lower it down
