Results 1 to 8 of 8
Thread: 2l head on 1.8
    Sep 2007
    perth western australia
    2l head on 1.8
    hi dubbers, cheers for the info on my airflow sensor, scored one from europarts and its on its way. will an audi block 2l 1991 go into my mk2 gti 8v ? i may have read a thread here in the past but could anyone give me an insight, as ive got my hands on a bargain car !! thanks
    Apr 2006
    Asaka-shi Saitama Japan (from Tassie)
    what prefix audi motor?
    and a 2.0 head on a 1.8 block will generaly lower compression...
    Cheers, Benny
    www.axesent.com.au
    Camden, Sydney
    The 2L has bigger intake ports so you would need to use a the audi manifold, but it comes out the wrong side, so you`d need a mk3 one which has a different throttle body. So not a straight bolt on. Better to use the 2L bottom end and your 1.8 head. Bolts straight in and is rapid.
    Feb 2007
    Have to say this because every time I asked about a 2L bottom end i got this response.
    "The 2L bottom end doesnt like to be revved"
    MK1 GLS 3door
    A4 B7 2.0T
    Quote Originally Posted by Spyda View Post
    That won't be so much of a problem if you are running a std head.
    If you have one that is ported and polished and maybe with a lumpy cam, then the lack of reviness will show up more.
    Sep 2007
    so that ,would i assume give me more power ?
    Sep 2006
    Banff, Canada
    Can't say I've had that problem. I'm running a 3A 2L, and it's an animal... I'm not sure about a newer 2L running digi though, this 3A runs harder than my 2E ever did...
    Canadian dubs coming to VWwA soon
    Sep 2007
    tricked out
    the audi is a 91 model , joe says there is alot of variations wth a 2 l block , yesterday i set the air flow meter a few clicks and it made a good improvement . i will go for the engine swap with the 2l and i got a set of leather vr6 seats to and tear drop alloys , just need to lower it down
